Adjusting color, brightness and contrast on my projector output
HI ALL,
Is there a way/node/setting to adjust/edit the brightness, contrast and saturation of my final video output to my projector in Lightact?
Many thanks
Hello Owson,
Sure it is. The most versatile way is to do it in the Projector layout where you can, for example, use Texture Contrast/Saturation/Brightness node
You have a bunch of other Texture processing nodes available to you as well:
Alternatively, you can adjust color correction in Canvas setup window as well:
I hope this helps,
Meetya
