Hi again,
just trying to get artnet time code for a playback layer. Is there anything that needs to be enabled for Timecode Sync box to appear under sequencer properties
thanks
Hi again,
thanks
Hey Jason,
There was a slight change about that. Now, there is an additional Sync tab on the right-hand side of the Visualizer and Assets tab on the top right corner of the main window.
Definitely need to update the documentation ![]()
Let me know if it works,
Ah ok. So this will Sync the entire composition (not just an individual layer) to timecode - same as if I am using LightSync protocol to sync between LightAct servers… cheers
