Bring 3D objects into Lightact?
Hey Mitja,
Are there any walkthroughs on how to import 3D objects into Lightact?
  • Roger
Hey Roger,
It’s not the latest (it was written for v3.0.0), but it should still explain it sufficiently. Have a look at it here.
A rough summary is:
  1. Import an obj file using Ctrl+D shortcut,
  2. place it in the Visualizer,
  3. create a Texture variable,
  4. set is using a Texture setter node
  5. select it as the Source in the Source tab of the object’s properties
It should look somewhat similar to this:
Let me know if this helps.
Awesome! Thanks again Mitja!
