Lightact Crashing when Enabeling Output
I am using LightAct4 EA7
Each time I enable my output to my projector (x3840 y0), LA4 crashes instantly.
I have changed my display settings to 1920x1080 so my projector is located at x1920 y0 but this still crashes LA4.
I have done this setup with a brand new download and new files just projecting the colourgrid and everytime I enable any output onto my projector LA crashes.
However, I am able to send data to the projector through nDisplay from Unreal Engine in 4k so I don’t believe it is a GPU problem.
Any help is much appreciated!
With further testing, any output other than my main monitor crashes LA.
I tested with a second monitor through HDMI and DP and both crashed when attempting to enable output to that region.
Hello Anthony,
Can you please share a video of your crash as well as the project file and the logs?
We have swapped machines for our testing and the second machine works perfectly outputting 2 additional projectors.
The second machine has an RTX3090 whereas the first has an RTX2080, so our conclusion was a GPU issue.
Although I have output video from my old home pc with a GTX1070 before so I dont know how the 2080 was freezing and crashing, either way we are currently able to progress with our troubleshooting.
Awesome. I’m glad you got it working. Like you said, it would be weird if the GPU itself would be a problem. My (wild) guess is that it’s a driver issue.
Might be worth checking out which driver versions are installed on both machines.
