Hi all, is there anyway to mirror/flip my projector output? Many thanks
Hello Owson,
Thanks for posting!
Sure it is. You just either double-click on the projector in the Visualizer or select it and in the View tab of its properties click on Open setup window button.
The Layout of this projector will open where you can use all the nodes available in other Layer Layouts.
Then you can simply use Texture flip node to flip the texture horizontally or vertically.
I hope this helps!
Thanks so much! big help! ![]()
