Hi
I haven’t been able to get a notch block to run in LightAct so far. I’ve exported a few different blocks for media server, and built the map in LightAct. The moment I select the block name in the Notch Block reader note, LightAct crashes out with a bug splat error. I’m using the learning edition of Notch and have tried LightAct 3.3.0 and 3.3.1
It turns out the most likely solution is to actually downgrade the drivers to either 431.98 or earlier. You can find them on this page.
Please try it out and let me know if it solves your problem.
p.s. the reason for this is in Notch’s SDK, which was only recently upgraded to support the latest NVidia drivers. It’s going to be implemented in the next LightAct release.
Thanks - is there a specific version of notch or requirements on how to compile the notch block? I’ve tried the new release and no crash, but I get an error reading notchblock. there is nothing in the log about why…
thanks
Are you having problems this block too? If not and you are having problems just with one specific block please feel free to send it over to us so we can investigate.
To state the obvious but very often forgotten thing (at least with me): you do need to have a valid Notch playback dongle connected to one of your USB ports. Otherwise you will get Block read error label in the node.
