Hi all,
I am working on an installation with 11x ArtNet nodes, each with 8x outputs / universes, and each on a separate IP address. So, I have a total of 88 universes in my LA file, and had set the starting universes for the 11x nodes in the Devices panel like this:
Node 1, 8 ports, start universe 1
Node 2, 8 ports, start universe 9
Node 3, 8 ports, start universe 17 etc.
When testing the lights with the nodes, we found that the hardware required the universes to be numbered 1-8. However, if all of my LA fixtures were on universes 1-8, they would all overlap and conflict with each other.
Is there any way to “remap” the universe numbers on output from LA? Ideally, I would still have universes 1-88 in LightAct, but each group of 8 universes would be remapped to the range 1-8 for each node.
(We are also reaching out to the hardware manufacturer to see if we can handle this on the hardware side.)
Thanks as always,
Scott
