Setting projector distance
Hi All,
Can you teach my how to setup the 3d visualizer projector projection?
I’m using a projector to project my video output on a wall, however I’m struggling to calibration the size of my output video, I wish to know how can I adjust the distance and rotation of my projector in visualiser 3d spatial so it can correspond to my output size?
Many thanks.
Since you are projecting on a wall (a flat one, I am assuming), have you considered using what we call a 2D projection mapping approach? It basically means you map the content to your projector directly from a canvas.
Then you can use warping and blending tools in Canvas setup window.
You can use Projection mapping sample project to find out more.
Also, this approach is explained in this video tutorial:
The 3D approach where you have a UV mapped OBJ object in the Visualizer and aim a virtual projector at it, is primarily aimed at projecting onto a non-flat 3D models. It requires a few more clicks to get it right. There’s also a big upgrade in this area planned for v3.2.3 .
Let me know if this helps,
