I embedded spout (sender) into my unreal engine project. If I run it in editor-mode everything runs smoothly and the Spout-Receiver receives the correct image. However, if I build my project (Package Project) and run the .exe nothing happens except a “fatal error” message appearing.
I already figured out that the connection between “Event Tick” and “Spout Sender” is causing the problem. If I disconnect them, everything works just fine (I just dont get my Spout-Out-Image :((( )
(I capture the Game Viewport. If you need more information to help me just ask for it!)
Thanks for your answer.
I already looked at the readme file and followed the instruction. It did not work. There is no further information in the error message… (“Fatal error! The game has crashed and will close now”)
I want to send the picture from Unreal to Touchdesigner. In the editor-mode it works, but as soon as I Package the file I just get the error message.
Spout plugin has been confirmed to work in 4.25. Please make sure you have both the Spout Sender and Close Sender node properly set up and connected in your blueprint.
