Video mapping onto an object
just a question on video mapping onto a 3d object. It seems that my box has the same video on each side, vs wrapped. Is there a UV mapping configuration I need to do?
thanks as always
Are you sure the object has the correct UV map? Lightact reads the information about the UV map and normals from the object file (obj) so you have to make sure your export settings are correct.
Yes my mistake… all good thank you
