Camera send data to LA from its display, not a lens
Hi.
I’m trying to connect a camera (not webcam, but Canon 700D) to LA. Actully I’ve already done that, following this tutorial: - YouTube; the only problem is that camera takes data from its display, which means that a texture, produced by camera, includes borders and additional data like FPS, reso, ISO etc.
Any ideas how to fix that?
Thanks for posting on our Answerhub!
I am afraid LightAct cannot change what your camera sends to it.
However, you might want to try Texture Crop or Pad node to extract the area you are interested in.
Ok, thank you for your answer
Hi It is Cannon case, You must turn of OSD :slight_smile:
Well, I pressed INFO-button several times and it removed those stats. Thank you!
