I’m testing a Master/Slave system before going with the real hardware.
I have 2 PCs on the same network. One desktop plugged with the Ethernet port and a laptop linked via VPN to the same network.
They both have the same Subnet address.
I’m using LightAct 3.7.6
I enabled LightNet and LightSync on both PCs and clicked Scan Network. No device found.
LightNet scan is a very simple UDP message which can be a bit susceptible to various network setup glitches for example firewalls etc.
Can you please send me a screenshot of network settings of both LightNet devices
as well as the relevant log file from the computer where you are doing the scanning.
Another thing to try would be:
add the second device manually and try to reach it then (by clicking ‘Enslave all others’ for example)
pinging the second device to check if they are reachable at all
