Continuing the discussion from Unreal nDisplay using other than Projectors:
Hi @Jason_Ellemor ,
Are you sure you copied your packaged project into a correct folder?
For example:
if my LightAct .la project file is in filepath G:\Testing\sampleProjects\officeProjection
then Unreal packaged projects should be in: G:\Testing\sampleProjects\officeProjection\assets\unreal folder.
Furthermore, the name of the executable should be the same as the name of the folder. In the example above, it means that the executables should be named projectionMapping.exe and uePluginDev.exe.
Let me know how it goes,
