Is there a specification for running bat files from Lightact?
I would like to consider a specification that would restart the PC upon receiving a UDP signal.
Hello Atsushi,
Good to hear from you again!
I’m afraid not, but it will be in the next version ![]()
Hello again @Atsushi,
I just remembered, probably you could also use Lua to do that.
I hope it helps.
you can use Chataigne
It manage a lot of device and protocol (module in chataigne) and manage in/out signal + show control aspect
In 3.6.4 (released today) we implemented Run .bat File node.
It allows you to do just that.
Nice idea, Atsushi! ![]()
Hi, meetya.
Thank you.
I was also able to create a .exe to run .bat in the Lua script and then run it and restart it.
I would also like to try the Run .bat File node.
Hi,John.
Thank you.
This sounds like an interesting application.
I didn’t know that.
I would like to try it because it seems to have potential to be used for other things as well.
